Orbi WiFi 7 RBE973
Reply
Strange behaviour RBW30
beckss1
Tutor
Dear comminity forum.,
I have RBR40 + RBW30 Orbi system and in past when I have problems with sattilite  disconnected I downgrade it to low version and upgrade it back.
Yesterday I downgraded manull it to lower versoin (checked after logoff - login back into web browser), but after small time break my sattelite upgraded automativcally to provious version.
In past I give it work on old version couple hours and I make this process myself.
P.S. In router I have defintions for not automatic udpate process.
Thanks and regards,
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 3
Guru
Re: Strange behaviour RBW30
Try a full factory reset on the entire system then setup from scratch. If you revert back to older FW versions, then auto updates may still happen.
Message 2 of 3
beckss1
Tutor
Hi.,
Thanks for you answer, but I don't downgrade router. Only sattelite I did.
Best regards,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 652 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
