Orbi WiFi 7 RBE973
Reply
Supported satellites for RBR50
jimgiordano
Follower
I'm looking for a list of models of satellites that are supported to work with RBR50.
Message 1 of 3
Retired_Member
Not applicable
Re: Supported satellites for RBR50
perhaps this will help:
https://community.netgear.com/t5/Orbi/RBR50-and-adding-satellites/m-p/1712862
Message 2 of 3
Guru
This is some good info:
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Sys...
Most RBS or RBWs will connect to the 50 series system. Just the speed rates seen on lower model RBS will change as they don't support the same backhaul speeds as the RBS50 do.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2510 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
