- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Switch stipped working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I'm glad you sorted the issue 🙂
Looks like you probably created a loop on your switch which caused your issues?
CheerZ
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Switch stipped working
Hi,
Have you checked the ethernet cables used for the switch? If the ethernet cables are ok then your switch could be 'toast'? Have you also tried directly connecting to the Orbi to check that the ethernet port that the switch is connected to is ok?
CheerZ
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the MFr and model if this switch your using.
There are known incompatibilies with some switches that are managed or have Green Ethernet features.
@orbimesh wrote:
Have an Orbi rbk50 connected to optimum router . From Orbi have a multiport Luxul switch . Wired connections stopped working . Tried rebooting , turned on off DHCP settings and rebooted . Any tips ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it was a simple fix. Please mark your thread as solved.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
CheerZ
