Orbi WiFi 7 RBE973
Reply
Turn off wireless backhaul when using ethernet backhaul
ileodo
Tutor
Hi,
I have a RBR50 and RBS50, and they are connected with eternet backhaul. Is there a way to turn off the wireless backhaul? so that I can free the wireless band occupied by the hidden network.
I did connected the router with telnet, and there are bunch of setting there, not sure which is controlling the hidden network. any idea?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Turn off wireless backhaul when using ethernet backhaul
Normally users can't disable it. Might see if there is a work around here though:
https://community.netgear.com/t5/Orbi/ORBI-RBK50-RBS50-Tips-Tricks-Hidden-Secrets-etc/m-p/1745266/hi...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1534 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
