Orbi WiFi 7 RBE973
Reply
Unable to connect some devices - NETGEAR Orbi AC3000 Tri-band WiFi System
maxram
Hello,
I am having problem with connecting some devices to my Wifi - (last night found that I could not get my son's Mac to connect to the Wifi)
I am running - Router Firmware Version - V2.1.2.18
Any help will be greatly appreciated
Thanks!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 11
Guru
Re: Unable to connect some devices - NETGEAR Orbi AC3000 Tri-band WiFi System
What is the Mfr and model# of the ISP modem? Any built in router here by chance?
What OSX version is the Mac using? What Mac is this device? Iphone? Laptop? iMac?
Try disabling the following:
Beamforming, MIMO, Daisy Chain and Fast Roaming if seen.
Message 2 of 11
maxram
Thank U for responding - I am not technically savvy - is there a limit on number of devices that I can connect - reason I ask is if all the people in my holusehold are using some device we get this problem - so issue is not really with only the Mac(be cause sometimes it connects without any issues) - it even happens when my wife sometimes turns on her Dell Windows laptop or I use my iPad (it feels like if there are quite a few devices I see this problem)
ISP is Spectrum (used to be Time Warner)
Modem is: Technicolor
Mac - Macbook Pro
Mac OS - High Sierra
I dont know where do I go in and disable this:
Message 3 of 11
Guru
How many devices are online and connected at one time?
Orbi system should be about to handle upwards of 30 devices est.
You can find these settings under Advanced/Advanced settings/Wireless Settings
I would also set Manual Channel 1, 6 or 11 on 2.4Ghz and any open unused channel on 5Ghz. Try 48 to start.
Set WPA2 and AES only.
Message 4 of 11
maxram
I went into Advanced Wireless Settings and found the following: (should I disable the Daisy Chain Topology)?
Backhaul Topology
Daisy Chain Topology is check marked
Beamforming, MIMO and Fast Roaming are unchecked
Message 5 of 11
maxram
Devices - approx 15-20
2.4 GHZ is set to 1
5 GHZ set to 48
WPA2 and AES only is selected
Message 6 of 11
Guru
ok, try channel 11 if thats not busy.
Let us know if the other suggestions help...
I would try this as well, have the mac connect while the other devices are disconnected. Then re-connect these other devices and see if the Mac disconnects after the others re-connect.
I'm using a older mac book pro, OSX 10.11. I have mac Mini with 10.12 loaded. Not seeing any issues with mine. Have about 20 devices wired and wireless. 2 NESTs, 3 Cameras, iPhones, iPad, Lenovo LT, two wireless USB adapters for PCs.
Message 7 of 11
maxram
Well - I brought the Macbook Pro close to the main Orbi router - and it connected fine - my worry is later in the evening when all the family is at home is when the issues start - some devices just refuse to connect (they can be Windows laptop or iPad or Macbook)
Message 8 of 11
Guru
Yes disable Daisy Chain as well.
After making these changes, see if the problem continues. Seems like something maybe causing devices to drop connection or being a connection hob maybe and something could be preventing all devices.
I would test this out when people get home. Leave the Mac Book connected, then have each other device connect to the wifi one at a time. Not all at once. I would ask your users to have them be present with you so you can see whats happening at each stage.
Message 9 of 11
maxram
Thank you Sir - I will do that and report back - appreciate your help
Message 10 of 11
Guru
Smiley Wink
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2801 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
