tdeutscher
Dec 30, 2017Aspirant
Unable to download file using Orbi Router
Hi All,
While I can browse any website, I am unable to download files of any size when connected to the Orbi Router (RBR50). The message shown is "Network Failure" with any browser i use to try to download a similar message occurs while using Internet Download Manager (app). When connected (hardwired) directly to my Motorola modem I am able to do so without a problem.
I have tried firmware manual updates and rollbacks to the router (including the most recent: V2.1.1.16) and it did not resolve the issue. This approach is super time consuming and while I could try each firmware image in the library I am not confident that will resolve.
I have factory reset the RBR50 to no avail as well.
Changing DNS Servers from Xfinity, Google and OpenDNS had no effect.
My modem has no wi-fi feature just as an fyi.
It's great having one-gig internet service but is a bummer when one cannot download a file.
Any guidance would be appreciated. Thanks!
Todd
PC/macs are various intel i7 machines with ac wifi cards or gigabit ethernet cards. Running OSX, Win 7 and Win10 Pro. Same issue with all.
- tdeutscherAspirant
Also, I AM able to download while using a VPN (e.g. Express VPN).
- st_shawMaster
There is no fundamental problem with Orbi downloading files, so it's got to be something about your network setup.
If you can connect to your router and download files from the Internet, it sounds like your modem may also be a router. In that case I suggest you configure Orbi as an access point.
Thank you for the reply. The modem is a Motorola MB8600 and has no router features. I can connect through Orbi to the modem (i.e. login to modem admin or go to the internet). Files just will not download. I used the IOS App to set up Orbi. Orbi is the network so there must be a setting within Orbit that is doing this (I guess). No sites are blocked in the Orbi Settings etc. My other comment is, that when I first set up Orbi i was able to downloand fine (June 2017). About three months ago it stopped. Sidenote, Orbi's Firmware update was set on Automatic, though today when I checked, it indicated no new firmware, yet when I went to Orbi support site, there was a newer firmware than that which as on the machine. Manually updating to that today had no effect. Thanks again.
- st_shawMaster
This is just a stab in the dark, but try reducing the MTU size. Maybe start with 1300 and work up from thereif it works.
See page 50 of the users manual.
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
