Orbi WiFi 7 RBE973
Reply
Upgrade from Nighthawk
bradleywilliams
I'm looking to upgrade from my 1-year-old Nighthawk R6700  to an Orbi RBK30 to extend my range of wifi.
Here is my question: Is it possible to trade in my Nighthawk for a credit towards the Orbi system?
Model: RBK30| Orbi AC2200 WiFi System
Message 1 of 4
Guru
Re: Upgrade from Nighthawk
No. You could use the RBK system in AP mode and disable the wifi on the R6700:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 4
bradleywilliams
Sorry, I miss-typed. I meant to say that I want to replace my single Nighthawk R6700 with a RBK40 + RBK30 system.
Message 3 of 4
Guru
RBK are kits which have a RBR (Router) and RBS (satellites). You would only need either RBK40 or 30, not both. You can not use RBRs as satellites. You can always add satellites as needed. Others have posted up to having 6 satellites.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2745 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
