- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Waiting for server response when setting up VPN with Orbi on MacOS
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm trying to connect to a VPN for work through my Orbi. I've followed the OpenVPN instructions using Tunnelbrick. When I do that I am never able to successfully connect to a server. It shows me this screen:
The only errors that I'm seeing in the logs are:
2022-01-31 16:01:47.983220 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 2022-01-31 16:01:47.983270 TLS Error: TLS handshake failed
Is there some other setting on the Orbi that I can change to get this VPN working?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CBR750 Modem | Wifi Router CBR750(v.7) | Switches NG GS105/8 and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Waiting for server response when setting up VPN with Orbi on MacOS
Does Tunnelbrick support have any information regarding this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
OpenVPN on a home router is intended to allow the owner to access devices on the local networkk when away. i.e. to get "into" the router from the internet.
Accessing a company VPN is entirely different and may require specific VPN software and security certificates. The company IT department should be able to provide that information.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
V2.7.3.22
Arris BGW320-505 AT&T
I hadn't checked. I assumed that it had something to do with the nonwindows VPN configuration with the Orbi router. When connected to the modem I'm able to use the other VPN configurations without a problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The problem is that the Orbi is blocking use of any VPN and the setup instructions (https://kb.netgear.com/25389/Enabling-VPN-service-on-a-NETGEAR-router-using-a-MAC-OS-computer) have led me to this point. I'm able to use the company VPN when I'm wired in to the modem with Tunnelbrick just fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Couple of options,
