Orbi WiFi 7 RBE973
Reply
What is maximum number of satellites for RBK852 or RBK854?
kayton
I am trying to cover a 7000 square foot multi-story building.  What is the maximum number of satellites than an RBK852 can handle?  Or is there a different system (like Nighthawk mesh) that might work better?  I need 1 Gbps or higher.  Thank you.
Message 1 of 8
Guru
Re: What is maximum number of satellites for RBK452 or RBK454?
Confirm this model number of RBK452 and 454? Is this Orbi or Nighhawk?
There a web page for this series?
Message 2 of 8
CrimpOn
Guru
Oh,dear. RBK452 or RBK454 are not Netgear model numbers.
It makes a world of difference what kindof 7,000 sq. ft. multi-story building this is.
(7 floors of 1,000 sq. ft. each?  2 floors of 3,500 sq. ft?)
and how the building is constructed.  Typical office building with concrete/rebar floors? Residential wood frame?  Warehouse?
If you post the question in the Orbi "AX" forum, someone may report the number of satellites they have added to one AX router:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Message 3 of 8
Guru
I would confirm model # first. There is only Orbi 7 and 850 series systems. I don't see any 4 series Orbi AX listed. Possible this is a RBK40 series?
Message 4 of 8
Guru
I see this over in the EU region:
https://www.netgear.dk/orbi/rbk352.aspx
Message 5 of 8
kayton
Thanks - I posted in AX forum.  House is multi-story with stone and cinderblock walls, so I will need many satellites.
Message 6 of 8
CrimpOn
Guru
Exterior walls simply reduce the impact on your neighbors.  Interior stone and cinderblock walls are horrible for WiFi coverage.
Message 7 of 8
Guru
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 640 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
