Orbi WiFi 7 RBE973
Reply
Which Satellite to add to a system with RBR50 and RBS50?
wolfereeno
Apprentice
Netgear'soverlapping products are so confusing.   I bought a 2 unit package that contains an RBR50 and RBS50.  I want to add a 3rd satellite.  Seems like the RBS20 is a cost effective option.  But whats the diff between it and the other various statellites?
Thx!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
CrimpOn
Guru
Re: Which Satellite to add to a system with RBR50 and RBS50?
The RBS50 has three sets of radios and antennas (separate antennas for the backhaul radios), whereas the RBS20 has only two sets (2.4G and 5G).  In practice, the backhaul speed is usually so great compared to the internet capacity that users notice no difference.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 353 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
