- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WiFi Slow after 2-3 days until reboot?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi Slow after 2-3 days until reboot?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like a memory leak (slow decline fixed by a reboot). Pure speculation on my part, FWIW.
See if latest firmware fixes that.
RBK50v2 downloads at https://www.netgear.com/support/product/RBK50v2#download
RBK50 downloads at https://www.netgear.com/support/product/RBK50#download
Be aware by reading other threads here of the problems encountered by people doing manual updates. There's some assurance if you are within the warranty period.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I may have made progress on this. After examing/disconnecting/reconnecting all WiFi devices on the network, I had forgotten about the small NETGEAR USB WiFi adapter (WNDA3100v2) dongle, which is connected to a Dish Network satellite VIP 722k box for the purpose of updating the program guide at 3am every morning. It's hidden behind the TV so easy to forget about.
I disconnected/reconnected it, and went into the network config screen for the adapter in the Dish Network box. I saw four copies of my WiFi network SSID (same exact string) - two for 2.4GHz, and 2 for 5GHz. I wondered why there were two copies of the SSID. I can only guess that it sees the main channel, and also the satellite backhaul channel as separate networks? I don't know.
In any case, I changed the SSID to the other 5 GHz copy (same name) and since then have not seen the slow down (it's been weeks).
If this was causing the problem, quite ironic that the adapter is by NETGEAR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have simiar problem.
I have Xfinity 100M internet service. My Orbi mesh router wireless attached devices become very slow speed every 7-10 days. They run less than 10-30mb/s when that happen. Wire attached devices are running fine.
After upgraded to V2.7.2.102, problem still exist... Now it happens consistanty every 2-3 days.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-port-forwarding-doesn-t-work/td-p/198...
@fc7737 wrote:I have simiar problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear Furry - This thread has been going on for about 1.5 years. Why do you feel the need to post your same canned response to this issue? It is not helpful or very enlightening.
At this point I believe it is readily obvious the RBR 50 has a significant problem for some users regarding wifi speeds dropping for no apparent reason. This issue has continued to plague many users through multiple firmware updates. Turning on/off various setting, hard resets, etc. does nothing to solve this problem (As indicated by many posts herein.).
Sorry for the rant but the tone of your post seems to want to blame the user for something Netgear should analyze and provide a fix.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Post is for new users, not for ones that have already responded. Each new user may have a different system and configurations. So were asking for feedback from new users.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Tbsteph wrote:Dear Furry - This thread has been going on for about 1.5 years. Why do you feel the need to post your same canned response to this issue? It is not helpful or very enlightening.
I have also experienced this on my RBR20, so it's not just your model. I suspect our models have some common HW/SW so the issue impacts multiple models. This is no surprise as every company does this; they don't design a similar model from scratch.
In any case, I suggest you start looking at every device that connects to the router - reset it, check it's network connection and SSID, reboot it, etc. I'm my case, I had a small Wi-Fi dongle that my satellite dish provider uses to download program guide updates and provide PPV. It's buried behind the satellite box so I forgot about it. I disconnected/reconnected the dongle, and re-entered the Orbi SSID into the satellite receiver, and since then I have not experienced the slowdown. My theory is the dongle somehow filled up some buffer after a few days and the slowdown happens. Just a theory...
The irony? The USB WiFi dongle is made by - NETGEAR.
Anyway - start looking at all the devices in your chain.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Furry,
Thank you for your suggestions.
Yes, I have hard reset my Orbi every time I updated my FW.
NG online support suggested the following:
1. Select channel 11 for the 2.4 GHz and channel 48 for the 5 GHz.
2. In the WAN MTU Size field, enter 1479
After applied the changes, the wireless devices speed went back to 100M - possible due to wireless part got reset after config change.
However after 24-48hrs, my wireless devices speed went back to 25-30M...
I have provided my feedback back to NG support and waiting for reply..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, thanks for letting us know. Ask about an RMA as well.
@fc7737 wrote:Hi Furry,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update v2.7.0.70. makes no sence.
I tryd this a few weeks. After 7 / 8 days the speeds goas back to 40 /-- 50 Mbs. in stead of 200.
I am considering selling this product.
You no longer have support after 3 months.
An expensive product that malfunctions.
Never expected this during my purchase!
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a more recent version:
Perhaps your units has been fust faulty from the start. Something to contact NG suport about to see what your options are.
Good Luck.
@Peter_summer wrote:Update v2.7.0.70. makes no sence.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had my unit replaced by Netgear about a month ago. They replaced the router and two sattelites with remanufactured versions. It made no difference. The same problem recurred with the "new" devices.
@FURRYe38 wrote:There is a more recent version:
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something to keep in contact with NG about. If you've tried everything and recent FW, then not much else we can help with here.
@eehirsch wrote:I had my unit replaced by Netgear about a month ago. They replaced the router and two sattelites with remanufactured versions. It made no difference. The same problem recurred with the "new" devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have already resolved this exact problem on my RBR20.
You must check every device on your Wi-Fi network. I would try to isolate a device that is possibly saturating the network and filling a buffer on the router. Try rebooting, disconnecting and reconnecting the SSID. Look particularly at smart TVs, Google/Alexa smart speakers, etc. vs. phones and laptops. In my case, I had a NETGEAR wi-fi dongle that was connected to my satellite dish box. It had not been disconnected since my last two routers. I disconnected/reconnected it and reassigned it to the Orbi wifi SSID thru my satellite dish box. After that, I no longer saw the slow 40-50Mbps speed drop, and speeds are now consistent.
I believe that the Orbi router does not handle this well, and a buffer gets filled and not emptied.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are completely right, I didn't buy stuff like TP Link Deco for $130 because surely this $300 NetGear device is the high quality stuff, plus its been out since 2016 all the bugs must have been fixed!
All I get is random disconnections and issues. I spent hours trying to fix this thing. I am telling everyone I know not to buy NetGear now. Routers are like printers, they kind of all suck unless you probably buy corporate stuff like Aruba or Meraki which has ludicrous prices(or subscritpion).
After many months of research the safest bet seems to be ZenMesh by Asus.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Orbi 50 series works well. No slow downs. Many factors that can cause wifi slow downs. No just FW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just want to add that as of August 2021, this issue still exists on my RBR50.
Doesn't matter what I do, Wifi speed will be only 25% of my ISP speed (U-verse -->120 Mbps) after 1-2 days.
Everything I have tried:
1). Tested with AT&T U-verse and Xfinity modems (I have both services)
2). Reboot and reset router and modems.
3). Firmware updates
4). Tried every possible wifi configuration (e.g. Disable / Enable Mimo, beamforming, change channel, etc.), reboot and unplug / plug router
5). Removed all devices and just have 1 device connected (laptop) and test the connection.
6). Test done through Google speed test, Fast.com and Speedtest.net and other sites
7). Speed test done with 4 MacBooks, 3 Windows laptops, 3 iPads, 3 iPhones and 4 Samsung phones.
6). Tried this over a course of a few weeks
You know what fixed it?
I borrowed my friend old ASUS router (RT-AX3000), configured it with the same SSID and number of devices and in the last couple days, NO wifi speed is halved across all 17 mobile devices and dozens IoT.
So with different router, I know it is NOT an issue with:
1). ISP modems
2). My devices (AppleTV, Mac, iPhone, smart vacuum, etc)
It's Netgear RBR50...
Just posting this to provide updates in case someone searched or Google this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-a-la-faq.65224/
You can revert back to stock FW if it doesn't work out for you.
1). ISP modems
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only reboot fixes it. Very frustrating for such an expensive device. I had a cheap router before this that I needed to reboot 4 or 5 times a YEAR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@orbcad wrote:
I have the exact same problem with my Orbi. About 3 or 4 days then speeds on the main router tank to 35mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am not sure if it's the same root cause as others'. The speed recovered after I turned IPv6 back on. For some reason I initally turned it off. You can test yours here http://test-ipv6.com/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would only be needed if your ISP supports IPv6.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found that my new iPhone 13 pro is much slower than my iMac, and it looks like turning off MU-MIMO solved the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
