Suli3
Sep 14, 2018Aspirant
Wired backhaul setup - device chain
Hi all,
Yesterday I got finally my Orbi system and installed it immediatly. Now I'm trying to establish an wired backaul and I'm not clear about the exact setup.
My Setup: My house has an integrated LAN system. Every room has one network plug with two ports. These are connected to a 16 Port Switch and after the swich is the modem of the cable provider. Besides the Orbi Router also few other devices (TVs, Playstation) are connected via the network plugs to the same switch
In other words: Cable Modem --> Router --> Orbi Router (connected to the yellow internet port)
I did the firmware upgrade of the router and satelites. This went without any problems. The wirless setup went also perfectly.
As a first tryout, i just connected the satelites to the LAN in one of the other rooms.
QUESTION 1: do need to plugin now the rooter to a noral port or still to the yellow internet port on the router?
QUESTION 2: does it matter which port on the satelites i use?
QUESTION 3: do i need to set the router to AP mode or does this not matter?
QUESTION 4: do the other devices on the switch (TVs, Playstation) distrub this setup
Loking to the setup this would mean: Cable Modem -> Switch -> Orbi system (1 router + satelites).
QUESTIOn 4: is the network setup ok or do i need: Orbi router --> Satelite 1 --> Satelite 2
Many thanks for the help.
Hi
Thanks for your reply.
I do not understand what you mean with Mft but this my setup:
Maybe I also explained it a bit wrong. It is not only a Cable modem it is also a router (inkl. Wlan).
(Cable 500Mb/50Mb)
UPC Connect Box CH7465LG-LC (Router ISP) --> TRN TEG-S16D (Swich unmanaged) --> Orbi System (RBR50 Orbi Router + 2 Satelites)
The router of the ISP provider and the switch are in the cellar.
QUESTIOn 1 again: Do i need to connect the RBR50 to the yellow internet port or to one of the other ports?
According to https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
Especially the third option i see (switch --> Orbi System (router + satelites) exactly how I did it or do I read this wrong?
Your advice Cable Modem -> Orbi system (1 router) -> Switch -><- Satellites and All other Network devices connected to switch
This would mean i would have the RBR50 Orbi router in the celler, where i do not need it. I want to have it in the flors where it is usefull.
What is the Mfr and model# of the ethernet switch if one is in the configuration. Non managed switch is preferred. Orbi doesn't like Managed switches. If you have a managed switch try to disable IGMP protocols on the swtich.Review this for configuration of ethernet connected satellites:
QUESTION 1: do need to plugin now the rooter to a noral port or still to the yellow internet port on the router? Depends if your modem or other router is in used. Yellow is normal.
QUESTION 2: does it matter which port on the satelites i use? No
QUESTION 3: do i need to set the router to AP mode or does this not matter? If you use a router upstream from the Orbi then use AP mode. If you use the Orbi after the ISP modem, then run it in router mode which would be preferred.
QUESTION 4: do the other devices on the switch (TVs, Playstation) distrub this setup. Should not, no.
Loking to the setup this would mean: Cable Modem -> Switch -> Orbi system (1 router + satelites). NO.
- Suli3Aspirant
Hi
(Cable 500Mb/50Mb)
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.The configuration I mentioned is preferred, however if your using a router already, then use the Orbi in AP mode. Yes you can use the Orbi in AP mode behind the switch in your configuration.
You can conenct the Orbi router using the Yellow LAN port to the swithc port. You can use the other LAN ports on the Orbi as well, however be aware you may see the top led on the Orbi turn on PINK. It's ok, just letting you know the LED behavior depends on use of the Yellow WAN port.
Mfr = Manufacturer
