- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
moving my orbi to different location
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to take my orbi system to work...few questions...1 the modem / router combo at work is a cradelpoint ..do i put my orbi router in AP mode for it to work & 2 do i use my password to connect...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: moving my orbi to different location
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just disable and turn OFF the wifi radios ON the modem. The modem portion is still needed to interface with your ISP services.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll need to contact your ISP or the mfr of the modem to find out how to exactly disable the wifi on the modem. There maybe a user manual as well. Maybe a phsycial switch or someting in the modems web page.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, that needs to remain diabled while you have the Orbi as your wireless. The modems wifi will no longer be needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can try. Having two or more wifi signals in close range can cause wifi problems and is not recommended. You can try keeping the orbi on channel 11 and 36 and the modem an 1 and 149 or higher channels.
- Mark as New
- Bookmark
- Subscribe
- Permalink
how do you set the orbi for those channels 11 & 36 ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi routers web page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well ...i just plugged orbi router into cradelpoint modem & then connected the Satelitte and it worked great...beautiful streaming all night long...no buffering...Thanks The Orbi is Great !!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
