Orbi WiFi 7 RBE973
Reply
outside of network access
masteroftheflam
Follower
have had my orbi for 3+ years, always worked perfect. have been able to access my WD mycloud NAS from with smart phone, pc etc., from outside the network with no issues. all of a sudden I no longer have access except from within network.I believe I inadvertantly changed a setting but can't figure out where. HELP
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 3
Guru
Re: outside of network access
Do you remember what area you were working in on the Orbi router that you might have made changes?
Port Forwarding or Access Controls?
Message 2 of 3
ekhalil
Master
I would check the following areas:
- UPnP & Port forwarding
- DDNS setting if you'r using one for remote access.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 925 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
