Orbi WiFi 7 RBE973
Reply
rbk22 -flashing white light
bobby071
I just bought a new orbi rbk22 system. The router keeps flashing white forever..
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 5
bobby071
Re: rbk22 -flashing white light
The customer service 24/7 number is also not working... Really I might just return this product.
Message 2 of 5
Guru
Are you walking thru the set up wizard after setting up the router?
What Mfr and model# is the ISP modem the router is connected to?
What FW is the router using currently?
Message 3 of 5
bobby071
My firmware is up to date. It is attached to verizon fios modem.
Message 4 of 5
Guru
What model# is the ISP modem the router is connected to?
What FW version is the router using currently?
Factory reset the router and walk thru the set up wizard. Use a wired PC connected to the router.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 816 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
