Orbi WiFi 7 RBE973
Reply
reset time
branty
Follower
reset time
i'm trying to reset my router, how long do i have to hold the reset button in for to get the orange light..
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
rinthos
Luminary
Re: reset time
From your signature you have an Orbi. Power on your Orbi router and wait about 2-3 minutes until it's fully booted.
Then using the paperclip, hold in the reset button for ~30 seconds (it takes only about 10 seconds, but it's ok to hold it longer).
Additionally, there's a great 2 minute video here, with reminders (this will un-pair your satleites, you need to reset them too, etc).
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Message 2 of 5
Mstrbig
Master
Re: reset time
If it's a stubborn one, which I've run across a few, turn off th Orbi, hold the reset button in and turn the Orbi on. Keep holding the reset button until you see flashing red power light.
Message 3 of 5
Guru
Re: reset time
Press the reset button for only 15 seconds then release is recommended for a reset.
Message 4 of 5
Mstrbig
Master
Re: reset time
Actually the textbook instructions are, which sometimes doesn't work:
Using a paper clip or similar object, press and hold the Reset button until the Power LED on your Orbi device blinks amber
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2208 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
