TAC57
Jan 23, 2021Aspirant
GS108Tv2 Can't write time?
I just unboxed a new GS108Tv2 that I've had in the box for quite some time. It seems to work OK, but I can't write the date message is "Error: Failed to set Local date". It won't take a new password either.
I've also tried to update the firmware and that doesn't update either.
- DaneANETGEAR Employee Retired
Welcome to the community! :)
Kindly try using other browsers or use Incognito mode in Chrome then login again to the web-GUI of your GS108Tv2. Check if the same problem will occur.
What is the current firmware version of your GS108Tv2?
DaneA
NETGEAR Community Team
