Retired_Member's avatar
Retired_Member
Dec 27, 2020
GS110TPv3 time schedule still not working after firmware upgrade 7.0.4.8
After upgrading my GS110TPv3 POE switch to the latest firmware release 7.0.4.8 which should fix the "across midnight time schedule bug" It still doen't work when I want to schedule to power down my POE ports one hour before midnight till 6am the next day. Scheduling within the same day seems to work just fine.
What am I doeing wrong, or is the "fixed" bug still present?
  • schumaku's avatar
    schumaku
    Already tried to drop and re-add the schedule?
    • Retired_Member's avatar
      Retired_Member
      Yes, have done that many times. I even tried to find a workaround, unfortunately no configuration will make the "day hop" schedule work.
      • schumaku's avatar
        schumaku
        Time zone er all is correct for your location?
        Reads to me like an issue to be escalated via support to engineering.
ProSupport for Business
