markster's avatar
markster
GS308T DNS and Time configuration and other issues
It has not been explained well in Netgear documentation what DNS setting are for and why we would need it. I know what DNS is but fail to understand why we need it on this switch. Can someone explain?
Also, configuring NTP on this switch always fails no matter what I do. I have Asus router that provides central NTP services to all my devices. It intercepts all traffice on port 123 and provides NTP service. Whatever I try, my local NTP server IP or pool.ntp.org it does not work and netgear switch complains with error Resource Time-Out. It is flaky implementation. Does anyone else have this problem? I am on the lastest firmware which also give me a issues. After I perform configuraiton changes the web interface would kick me out back to the login page. Every time I make a update or change this started to happen. I would reset the switch, it would work and after a while it starts again.
  • schumaku's avatar
    schumaku
    The DNS config allow the switch to run name resolution, e.g. for SNTP purposes.
    Switches are using SNTP- this is almost an industry standard, much easier to implement, less complex than NTP - and for the sake of it not always backward compatible. Nothing flaky here...
    • markster's avatar
      markster
      Well, I am not convinced. I tried using R7000 and this new Netgear switch GS308T configured to use pool.ntp.org. Both devices have the same issue trying to use it. If you say it is standard - I would say that netgear needs some work to make it right. pool.ntp.org is a standard NTP service. All my devices, Smart TV's LG,Sony, my Mac and Asus Router use it without any issues. Only Netgear devices have a problem. What is that telling you?
      As for DNS setting. It would make more sense that this setting is inside Time configuraiton so people would know. It is more intuitive. Hope Netgear is watching this and think about the interface. Not helpfull. The Help menu is not mentioning anything about DNS setting being related to time resolution only -as you pointed out. These little things are really bugging me about the Netgear devices and software.
      • schumaku's avatar
        schumaku
        DNS is a part of the system configuration, along with the IP stack configuration, for whatever feature(s) it's used internally on a device. So this is where it belongs to in an UI ... not cluttered somewhere along with the time service because it might be the only usage there. It's part of a standard feature used all over on many different switch models here with Netgear and various feature sets.  NTP and SNMP work nicely with an IP address, if the user does define a hostname or FQDN with a service, it requires some kind of name resolution, here DNS. Just like on any computer.
         If this description is appropriate, and the router does intercept the NTP traffic on port 123 nothing will ever go to another device configured server - well possible SNTP might not work on this NTP relay service (just like some other ntpd implementations).
        No idea where your R7000 issue is coming now from - a complete different story. undefined firmware, undefined configuration, ... would not wonder if these devices have limitations e.g. in AP mode. These consumer routers make use of a simple ntpdate (like many of the systems you claimed workable - ways off from a real NTP functionality. On the protocol side, there is nothing that should stop it here.
ProSupport for Business
