Gs110TP's avatar
Gs110TP
Follower
Jun 27, 2018
Looking for the MIB for the GS110TP
I'm looking for the MIB for the GS110TP. It would be great if i could just download it from the support site.
I'd like to read the PoE status.
Kind Regards, Ivo
  • Hi Gs110TP,
    Welcome to community! :)
    Here us the MIB for the GS110TP. No password needed and the link will expire after 48 hour period.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi Gs110TP,
ProSupport for Business
