- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Network Loops causing our devices to freeze
- Mark as New
- Bookmark
- Subscribe
- Permalink
We’re experiencing a lot of NetGear Prosafe switches freezing, and we’re forced to do a reboot on all switches twice a week as we cannot trace where the issue is coming from. We are looking on a possible loop issue, and while this is a fact, finding the loop itself is quite a feat, that’s why we are trying to find a way on viewing the CPU and Memory utilization and verify which switch we should focus on.
Hardware |
Software |
FS728TPv2 |
5.0.2.39 |
GS728TP |
6.0.1.18 |
GS724TP |
5.2.0.11 |
GS724Tv3 |
5.4.2.10 |
GS748Tv4H1 |
5.4.2.30 |
FS726TP |
V2.0.1_14 |
GS748Tv4H1 |
5.4.1.17 |
GS748Tv4H1 |
5.4.1.17 |
GS748Tv5 |
6.3.1.19 |
We’ve tried using an open-source 3rd party monitoring tool as well as NetGear Network Manager (NMS300 version 1.6.0.11) on the latest NMS version, unfortunately it still wasn’t able to show the CPU and Memory utilization we are looking for. We also tried checking on the MIB files both on NMS300 and 3rd party monitoring tool and MIB files available on the downloads page on NetGar website, only generic MIB files are available for download which doesn’t include CPU and Memory Usage.
We are reaching out to you to assist us finding a way to view CPU and Memory Usage on the above given switches either via the switch admin portal or NMS, or if you know someone we can escalate this issue so we can get immediate assistance from NetGear.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS748T-v5-CPU-Usage/td-p/1302836 - sorry, some odd chars added on the original reply.
@Palladium wrote:
Also, does that mean that all the switches provided are not managed switches, that's why the CPU and Memory usage cannot be viewed via NMS300?
Afraid, yes - exactly explained in the older thread already, too.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network Loops causing our devices to freeze
STP or RSTP are your new friends.
Any devices or components on your network potentially playing "bad" - like wireless bridges, media players (e.g. SONOS), sophisticated storage and App server systems with software defined networking (like QNAP QTS)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello @schumaku,
Thanks for the response.
Just a quick follow thru questions below.
1. Do you consider satellite dishes as wireless bridge?
2. Will it have any service impact if you enable STP / RSTP on the network immediately? The switches are connected more like star topology.
3. Any way we can setup CPU and memory usage for the devices stated on my initial post?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anything that can cause a potential loop - especially when there is some redundancy in the play.
If available all over go for RSTP. You will find that only one part of your star architecture be forced disconnectred worst case - instead of knowcking the complete system down. This should allow some localized troubleshooting later on.
The moment when CPU and/or memory usage would explode (if it does at all - it's more likely traffic on links, typically broadcast ...) will be the moment you loose the in-band management access to the switches anyway. Not sure why you are so keen for it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
WHello @schumaku
Thank you for the answer.
We are keen to know the CPU and Memory usage for each device since we would like to know which device we should reboot instead of rebooting all devices when the network goes down, because we don't know which switch freeze.
Is this possible on those switches provided?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello @schumaku,
Good Morning.
We would like to follow-up if there were such a way to view the CPU and Memory Usage statistics and if it can work on a monitoring/snmp tool for the devices stated above.
Thanks,
Marlon
- Mark as New
- Bookmark
- Subscribe
- Permalink
As per this older thread -> https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS748T-v5-CPU-Usage/td-p/1302836
"As per the higher tier of NETGEAR Support, the CPU utilization / memory in the NMS300 is available for the NETGEAR Managed Switches only" - because it's not available in the SNMP MIBs one might guess.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @schumaku,
I am getting an error opening the page, can you re-paste the link you provided? Thanks.
Thanks,
Marlon
- Mark as New
- Bookmark
- Subscribe
- Permalink
