Orbi WiFi 7 RBE973
Reply
QoS Prioritisation using DSCP/DiffServ with Linux and XS708Ev2
blueSpirit
Follower
Hello,
I'm trying reduce the mean-delay (round-trip-time) of my PTP packets when going over a switch and generated traffic by increasing the DSCP priority - but without success so far.
I have a XS708Ev2 and two types of data
  • low priority iperf data with 9k packet size
  • high priority PTP multicast data with about 100 byte packet size
I ve set the QoS of the XS708Ev2 to "802.1p/DSCP-based" (which was the default) - see attached screenshot.
Further more I ve set the DSCP field of the multicast traffic on both - sender and receiver - to CS5:
  • sudo iptables -t mangle -A POSTROUTING -d 224.0.0.0/4 -j DSCP --set-dscp-class cs5
I'm not using 802.1p - so there is no VLAN tag which could overrule the DSCP value.
I verified this by wireshark:
  • low priority (CS0) iperf data
  • high priority (CS5) multicast PTP data
Is there something wrong with my approach - or is there another setting to enable QoS in the Switch?
I ve seen other configuration menus, which have some CoS sub-menus under QOS - but in my case only the port-based or DSCP-based setting is selectable - is this enough to get it working?
Thanks a lot in advance,
Karl
Model: XS708Ev2|ProSafe Plus 10G 8 ports switch
Message 1 of 2
DaneA
NETGEAR Employee Retired
Re: QoS Prioritisation using DSCP/DiffServ with Linux and XS708Ev2
@blueSpirit,
I suggest to open a chat or online support ticket with NETGEAR Support here at anytime.  Kindly state your objective as well as the steps you have done so far.
DaneA
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1413 views
  • 0 kudos
  • 2 in conversation
Announcements
