Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Smallest switch that supports Link Aggregation
playplay
Tutor
Hi guys,
I'l looking for a small 5 ports ethernet switch that supports Link Aggregation for redudancy (I am on Mac).
The GS305E looks perfect for my needs but I found opposite informations online whether it does LACP or not. Can someone help me?
Thank you!
Message 1 of 5
Accepted Solutions
playplay
Tutor
Re: Smallest switch that supports Link Aggregation
After talking multiple times online with Netgear's support it loks like no 5-ports handle LACP so I'm going to get the 8-ports GS308T.
This is the most portable ethernet switch that does LACP.
Thank youy guys for your heklp!
Message 5 of 5
All Replies
Guru
If you look up the data sheet for the GS305E, it doesn't support link aggregation.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
playplay
Tutor
Thank you @plemans . Which one would you recommend then keeping in mind size is of the essence here?
Message 3 of 5
schumaku
Guru
Both the GS305E Tech Specs and the GS308E Tech Specs in the Web as well as the GS305E and GS308E Data Sheet are "correct" and fit your observation:
L2 Services - AVAILABILITY
Link Aggregation/ Port Trunking: No
Number of Static Manual LAGs and # of members: N/A
@IphieChen plase - what's the point here? These switches were announced with lin aggregation LACP support.
FMI: Idea Exchange for Business - Link Aggregation for GS308E
Message 4 of 5
playplay
Tutor
Message 5 of 5
Discussion stats
  • 4 replies
  • 6396 views
  • 1 kudo
  • 3 in conversation
Announcements
