Eberhard_Mu's avatar
Eberhard_Mu
Follower
Apr 10, 2021
S3300 WOL
I need help to get WOL packets routed. I have 3 switches connected by LWL:
Server-S3300 #1-S3300 #2-S3300 #3-Workstations
I can not send magic packets from my server to all workstations, on every switch.
I already tried:
1. switching off green ethernet on all switches
2. security - traffic control - storm control - enable unicast/multicast/unknown with 5% (even if WOL is usually multicast)
3. switching - multicast - IGMP snooping enable
Nothing works :-o
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Eberhard_Mu,
    Welcome to the community! :)
    What is LWL?  Are you referring to LAG (or LACP)?
    Are the WOL Settings properly configured on the workstations?
    What is the current firmware of your S3300 switches?
    As a test, using just one S3300 switch, connect 1 workstation to it then check if WOL will work.
    DaneA
    NETGEAR Community Team
    • schumaku's avatar
      schumaku
      What is LWL?
      German TLA for fiber - LWL, Lichtwellenleiter.
ProSupport for Business
