× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Does the XAV5201 show up in Genie Network Map
jaybennett
Does the base unit show up in Genie Network Map when set up properly?   Or just the XWN5001?   I only see the XWN5001.   I am not sure I set the pair up properly.
I was trying to add a second XWN500q to an existing pair of powerlines, and I goofed up the configuration.  So I was trying to set the original pair back up and I am struggling.  And I may have the non-factory pair paired.
What seemed to work was perform a factory reset on both units.  Then use the security button to pair them.  Then I used the WPS button on the router to configure the wireless.  I have no proof that the SSID and password were copied to the XWN, other than the blinking stopped eventually.   Since either my iphones or router are a little flaky, I am not sure the wifi is extending.  I'll check it tomorrow.
Is the XAV5201 base unit supposed to show up in the Genie Network Map?
Message 1 of 2
Re: Does the XAV5201 show up in Genie Network Map
Mine does.
I have nothing else connected, which is why it is on its own.
Message 2 of 2
Discussion stats
  • 1 reply
  • 795 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
