- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
PLW1000 Existing WiFI
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just installed my PLW1000. Do I no longer use the exisiting wifi I already had? Is there a way to merge them? Or do I transfer all devices to the new Netgear wifi and use that one only?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: PLW1000 Existing WiFI
It is up to you. If the PLW1000 does all you need, then just us that. Many people use two or more wifi sources to give them better coverage.
Again, it is your call.
You can give your wifi networks that same SSID and passwords to make life easier for wifi clients. But bin those circumstances some wifi clients could get confused and lock on to one source when they are actually nearer one with a better signal.
There is a manual for the device somewhere at the end of this link:
>>>> PLW1000 | Product | Support | NETGEAR <<<<
You'll have to dig out the instructions for your other kit.
