- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Powerline PLW1000 slow speed unless rebooted?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys,
I've had my PLW1000 kit for over a year and has seen a total of 3 houses. The first two houses it worked great with no issues whatsoever. I've just recently moved into a new-build house with new electrics. I believe the house has two rings, with a circuit breaker downstairs. My router is downstairs and the target computer is upstairs. I've set it up so the WiFi plug is upstairs and the standard plug is next to the router downstairs.
My internet wired receives roughly 35mbps with 20ms latency. After trying the powerline, all was great as I was seeing pretty much same results as directly wired - happy days. The next day, the latency had droped to 150ms and the bandwidth was at 2mbps. After looking on mywifiext.net, the Tx/Rx Rate was ~300Mbps which seemed strange. I thought I'd give rebooting the extender a try using mywifiext.net and as soon as it was up and running all was perfectly fine. Same again the next day though. I am now in a cycle of rebooting my Powerlines every morning to achieve full potential, which I find really weird. There are no large appliances running in the house overnight, pretty much every electrical device is off.
It feels like the kit is going into some sort of sleep mode and not really waking up. As I say, I've had the kit for over a year with no issues like this, only when I've moved into the new house has it started to happen. I've tried to update the firmware using mywifiext.net but it says I'm up to date (V1.0.0.6).
Any comments/suggestions would be greatly appreciated.
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Powerline PLW1000 slow speed unless rebooted?
That's a strong possibility.
You will find various messages about that around here. They may put you on the right track:
Netgear Powerline 1000 - NETGEAR Communities
Solved: Re: Power line 1000 connectivity issues - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks for the response.
The top link you have provided, I followed that yesterday and downloaded Zyxel's utility and turned sleep mode off on both adapters. I don't want to tempt fate but I woke up this morning and the speed is as how it should be. I'll keep you posted but it looks like it's sorted 🙂
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well done.
That would be great.
Pity it takes Zyxel to mend Netgear's hardware.
