Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Using powerine adapters across two separate power rings
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-11
04:47 AM
2012-10-11
04:47 AM
Hi
I am looking for some assistance in trying to use powerline adapters in my house.
The house has two separate mains rings.
One in the original house and a separate one in an extension.
I am trying to get connectivity around the whole building.
I have my adsl router plugged into the house ring, and I have a separate network switch plugged into the extension ring mains. these two devices are linked with an ethernet cable.
I have plugged a powerline adapter into the switch in the extension, and it allows me to use powerline devices throughout the extension.
Separately I have connected a powerline adapter to my router in the main house, and it allows me to use powerline in the main house.
However if i connect a powerline device to the router and additionally to the switch, I get no connection at all , and my internet connection does not work.
Is it possible for powerline adpaters to be configured to allow this to work, or can I use them in only one of the locations (i.e. the house or the extension, but not both)
Any help would be appreciated.
Message 1 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-11
05:57 AM
2012-10-11
05:57 AM
Re: Using powerine adapters across two separate power rings
It has to be on same circuit.
It will not work going to work with two different circuit 🙂
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-11
06:58 AM
2012-10-11
06:58 AM
Thanks for the response.
I will just have to switch them on separately.
So I can use powerline in one side of the house or the other.
But unfortunately not both at the same time. 😞
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-11
01:30 PM
2012-10-11
01:30 PM
If you are able to connect pair on each circuit and you can connect router then that is fine.
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-12
03:07 AM
2012-10-12
03:07 AM
Hi
Can you clarify, your last response.
If I connect one pair on the ring in the extension (connected to switch)
and one pair on the ring in the house (connected to router) , it does not work.
Thanks
Thanks
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-12
05:12 AM
2012-10-12
05:12 AM
That would not work.
You need physically connect both pair on EACH circuit separately, bldg1 & bldg2
ethernet cable from BOTH bldg can connect to main router then it will work.
Message 6 of 6
Announcements
