× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wireline unavailable
Sissy2022
Follower
All my lights are green and it’s not allowing it to connect to internet why?
Message 1 of 3
Guru
Re: Wireline unavailable
Powerline? Is that what you mean?
What device do you have?
Is this a new device? If so, you can always contact support to help with the initial setup.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
Message 2 of 3
This section is all about Mobile Routers, Hotspots & Modems. Is that what you own?
As @plemans says, you'll have to tell people what devices you are trying to fix.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
Message 3 of 3
Discussion stats
  • 2 replies
  • 395 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
