Cykuta's avatar
Cykuta
Problem with rediscovered device and online acces via web and mobile app ReadyCloud to local NAS
Hello everybody.
I use ReadyNas 104 localy in LAN and WIfi network and with this everything is ok.
I vave connected Nas to router via LAN cable. Router have the modem ADSL+ to internet (Polish provider Orange Neostrada) with dynamic IP. FOr dynamic IP I use dyndns.org portal.
Til few monts ago My device was registered under ready cloud app and I have connectin to my local nas.
But till few months I have problem to connections via ReadyCloud app (android) to my NAS.
I try to convert my account to mynetgear. I think with succesfull but device is still not worknig.
At the moment my anline account doesnt see my local device. My mobile app dont see any device. My local device monit that they dont have connections to internet (screen i attached file).
I;m looking person , any help to guide me ste by step how to check or do new configuration to have acces to my loccaly file online from mobile app website.
When I put dyndns.org adress name in browser I have acces to admin panel of local ReadyNas. So connection to internet must be.
Im lost in configuration - ReadyNAS - Router - website account - mobile app -> to match for properly work.
I will thank You for any help in advance.
If any input date is neccesery please let me know.
Im waiting for support for experience user.
Regards
Michal
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi Cykuta
    Welcome to the Community!
    Have you tried toggling the ReadyCloud service on your NAS? You may want to try rebooting your NAS as well to have the LeafP2P serviice restart.
    If you have already migrated your ReadyCloud account to a MyNETGEAR Account then it should work normally on ReadyCloud. Also, please make sure that your ReadyNAS system is up to date with OS 6.9.3
    Hope this helps!
    Regards
    • Cykuta's avatar
      Cykuta
      Hi Marc_V
      Thank You for You comment and suggestion
      Below my answer:
      Have you tried toggling the ReadyCloud service on your NAS?  - From where place software should I do this? When I log loccaly to the device (via local IP adress which I set as static i LAN structure I see that user is login but above I see monit that ther is no connection to internet - guestion mark says that ther is some problem with DNS or something)
      What should I put here: setting ReadyCloud ?
      Also should I set something dedicated to NAS connection from outside on my router with modem (ADSL+2 connetion with dynamic IP)
      You may want to try rebooting your NAS as well to have the LeafP2P serviice restart. - I try it. unfortunetly no changes :(
      If you have already migrated your ReadyCloud account to a MyNETGEAR Account then it should work normally on ReadyCloud. - How can I check that I properly migrated to MyNETGEAR account? At the moment I dont see my divece on Ready Cloud web site and mobile app. Where should I log to try match / find device from the beggining?
      I can log into https://www.netgear.com/mynetgear/portal/myProducts.aspx
      - thats mean my migration to MyNetgear was OK? I saw that screen.
      I can log in also to :
      http://readycloud.netgear.com/client/index.html#page=discoverdevices
      http://readycloud.netgear.com/client/index.html#page=access
      But why I can't find / discover my device on this site.
      Also, please make sure that your ReadyNAS system is up to date with OS 6.9.3 - My OS is 6.9.3.
      Could You please advise me next step to check?
      Can I count on any online help from producer Netgear site? Support desk or something like that?
      Regards
      Michael.
    • Cykuta's avatar
      Cykuta
      Marc_V wrote:
      Hi Cykuta
      Hope this helps!
      Regards
      Hi Marc_V
      Below my answer:
      Regards
      Michael.
      • Marc_V's avatar
        Marc_V
        Hi Cykuta
        Have you tried setting up DNS when you have set the IP to static? Also is your Internet connection working on other devices?
        Here is a link to update your NAS but please make sure you follow the instructions carefully.
        Regards
ProSupport for Business
