× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Anyone tried/accomplished a Kerberos/Bluecherry/Zoneminder/Xeoma setup on X86 OS6?
Darkyputz
Hello...
I try to get a opensource IP cam dvr working on the OS6 Readynas i do have...
But for soem reason i always end with some issue right at the end...
For example, i got Bluecherry all up and running to point where you set up the client software but it does not find configuration file...and i dont know how to fix it...or other exapmple...Kerberos.io...
Get everything to a point where cmake does not find opelssl and thats where i end with my fixing skills...
So hopefully anyone has anything like that going and can help...
Message 1 of 2
Darkyputz
Re: Anyone tried/accomplished a Kerberos/Bluecherry/Zoneminder/Xeoma setup on X86 OS6?
I got it working...
2.8.7 version...only problem at all was to change the rights on the /etc/bluecherry.conf to 777 and it worked right out of box...took just a few min on chat with support...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1011 views
  • 0 kudos
  • 1 in conversation
Announcements
