PaulAM787's avatar
PaulAM787
Follower
Jan 06, 2022
Netgear NAS 102 colume locked?
Hi,
One of our sites is having issue with a Netgear NAS102, its not something we setup or use so im a bit lost, it states as shown that volumes are inactive but also shows an orange circle with a white key  - i assume this means the volume is locked.
we have connected what appears to be the recovery USB for the NAS but this hasn't unlocked the voumes, can anyone point me where i might be going wrong or if i have a larger issue?
1 Reply
  • StephenB's avatar
    I believe the lock you are seeing means the volume is encrypted.  Is the USB device you connected actually the encryption key, or is it something else?  Did you try rebooting the NAS with the encryption key in place?
    The inactive volumes message might be a side effect of not using the correct key - not sure, as I don't use disk encryption on my ReadyNAS.  It also could mean something has gone wrong with the volume (for instance RAID out of sync).  Either way, USB recovery won't solve this issue.  You could try Netgear paid support.
ProSupport for Business
