JulienVdG's avatar
JulienVdG
rsnapshot installing overwrite busybox as logger
Hello,
I found several topics on rsnapshot but none covering my problem so I guess creating a new one is fine...
I installed Rsnapshot 2.3 on my readynas NV+ running raidiator 4.1.14 and it looks like it mostly works (I don't have email for the daily run while the hourly works... but well...)
Anyway, the release say "add the logger program" but I guess it worked badly on my case as the busybox program (/bin/busybox) was replaced by the logger binary. After reinstalling raidiator 4.1.14 I got back the busybox binary (but it was not that easy as the installer was using md5sum from busybox...)
I guess the addon installer could check if /usr/bin/logger exists before installing it (especially if it's a link to busybox!!)
best regards
ProSupport for Business
