curtisw's avatar
curtisw
Follower
Jul 30, 2016
Help with file premissions
Hi everyone,
I want to set permission for users to access the file share.
When I select Shares-->Sare Listing --> CIFS --> Share Access Restrictions section:
The check box of Write-enabled users is grey and I cannot check whatever I choose.
May I know why?
    • JennC's avatar
      JennC
      NETGEAR Employee Retired
      Hello curtisw,
      Maybe your default access is set to Read/Write where you do not need to enter any users in the Write-enabled users field and groups for group -enabled groups field).
      You might want to see also this KB article: How to set ReadyNAS Share Access (RAIDiator 4.x)
      Welcome to the community!
    • JennC's avatar
      JennC
      Hello curtisw,
      We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
      If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
      The Netgear community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
