adiamond2
May 18, 2016Aspirant
How can I copy files from the NAS using it's USB port to a USB drive
As I understand it, the RN104 has a USB3 port and USB3 can transfer files at about 500MB/S. If I copy from the NAS over my PCs USB 3 ports I get about 50MB/S. So, I would like to transfer it directly from the RN104 via its USB 3 port but I don't know how to do this nor do I see an article about it. FYI, ny USB3 drive seems to be formated with FAT32.
I see stuff about using the backup procedure and copying the other way (to the NAS) but not copying random files from the NAS to the USB drive (directly)
- mdgm-ntgrNETGEAR Employee Retired
If you are backing up an entire directory you could use a backup job with the directory on the share on the NAS as the source and the USB disk as the destination.
You may find this article helpful: ReadyNAS Backup FAQ
