deanosauruz's avatar
deanosauruz
CM500 Cable Modem Downstream Constantly Flashing Green
My Modem Details:
Hardware VersionC312T00-01
Firmware VersionV1.01.12
Cable Modem Serial Number48L50B7FA3805
CM CertificateInstalled
CM MAC94:a6:7e:18:35:bc
My Issues
For the last week I have noticed download speeds have been a little troublesome.
I browsed some discussions here and found people posting their modems logs, so i thought I'd take a look at mine and i see CRITICAL and WARNING everywhere.
I have no idea what the language means so i felt posting here was the best solution to hopefully rectifying why the downstream light keeps blinking green
Modem Logs
2021-9-12, 14:52:57Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 14:52:56Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 14:01:25Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 14:01:06Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 13:54:37Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 13:54:33Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 12:50:08Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 12:50:04Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 12:38:11Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 12:36:44Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 11:38:20Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 11:38:08Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 11:14:11Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 11:13:59Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 11:08:36Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 11:08:24Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 10:42:57Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 10:42:54Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 10:32:06Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 10:31:33Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 07:05:30Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 07:05:29Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 05:39:21Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 05:39:12Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 00:45:22Warning (5)MDD message timeout;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-9-12, 00:44:32Notice (6)TLV-11 - unrecognized OID;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
1970-1-1, 00:00:30Notice (6)Honoring MDD; IP provisioning mode = IPv4
1970-1-1, 00:00:21Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:21Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:31Critical (3)No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:27Critical (3)No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:33Critical (3)No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.0;CM-VER=3.0;
2021-5-26, 01:47:22Critical (3)No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.0;CM-VER=3.0;
2021-5-26, 01:47:12Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:18:35:bc;CMTS-MAC=00:01:5c:79:c6:4f;CM-QOS=1.1;CM-VER=3.0;
2021-5-26, 01:47:11Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:18:35:bc;CMTS
  • plemans's avatar
    Your logs are indicating line issues.
    do you have a screen snip of the cable connections page?
    Check for splitters, signal attenuators, and amplifiers in line. Remove them if you do.
    check the line for kinks, damage, old/loose/bad/corroded connections and replace them if needed.
    I'd move the modem to right where the coax enters the home and connect it there.
    • deanosauruz's avatar
      deanosauruz
      After checking the cables I find no erosion ordamaged cables, and I do not have any splitters, signal attenuators, and amplifiers.
      the modem is as close to the coax entry point as physically possible.
      Could there be a damaged line outside?
      I speed test and i get acceptable speeds yet sometimes a website on my desktop will show a DNS failed page buit then within seconds suddenly appears to load the page....
      I have attached a screen capture of the connections page
        deanosauruz
        For some reason the attached image didn't appear with my reply.
