- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to add a mac address access control
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am a bit confused here. I see that there is the access control page, but I can not figure out how to add a new iPad?
Rachael
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to add a mac address access control
- Mark as New
- Bookmark
- Subscribe
- Permalink
But we will see what happens when the new ipad arrives on the 4th.
Thanks Andy
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which router can max mac filter?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The WDNR4500 has always been trouble, and I just got tired of it. I got that router so I can print from my iPad, but that never really worked without messing everything up with apps on the iPad and then it was a pain in the buns to print from the desktop.
So thanks for your help. One less router and a bunch less problems
Rachael
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am on version V1.0.1.40_1.0.68
The only option button I have on that screen is DELETE.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reset to factory?:confused:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enter MAC
Enter a name
Press Apply
- Mark as New
- Bookmark
- Subscribe
- Permalink
I cannot believe you guys have not seen this issue, when your test team was validating the new firmware.
This is a critical error in my opinion.
Trust and reputation are not something you have over overnight. BUT you can lose them overnight.
Please listen what customers are saying.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: To add MAC address of my printer to my NETGEAR router (WNDR3400v2)
How to add MAC address of my printer (HP officejet Pro 8600 N911a) to my NETGEAR router (WNDR3400v2)? I cannot find any option to add MAC address to the router through NETGEAR genie!! Can you please help??
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @uperez,
Welcome to the community!
Are you trying to add the MAC address for Access Control feature?
The Access Control feature is added if you upgrade the firmware of your router to the latest firmware version 1.0.0.52.
To upgrade the firmware of your router, see the instructions here.
Let us know what happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, Elaine. I have upgraded the firmware to 52 from 38. I can see my printer is listed (MAC address) as allowed device to connect on the list but it is not connecting. I tried to connect the printer using the ssid and password but still it is not connecting. Please note that the same printer I connected wirelessly using the same rounter but now it is not connecting now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@uperez Will it connect without Access Control feature enabled?
Do you have the correct password to connect the printer?
Other devices can connect with the Access Control enabled?
Looking forward to your response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It does not connect in any way. Yes, I have the correct password.
Actually, my router has dual bands and two SSIDs: Netgear 50 (2.4 GHZ band) & Netgear 50-5G (5 GHZ band). All my other devices connect to Netgear 50-5G, but not to Netgear 50. I created two separate passwords for two SSIDs. The printer can only find the Netgear 50-5G (5G) band, not the Netgear 50 (2.4G) band. Please advise.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@uperez No wireless devices can see the Netgear 50? Tried changing channel? Make sure SSID broadcast is enabled.
If you still can't see the SSID, verify if you have the latest firmware installed then reset after firmware upgrade.
See if it will do the same thing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey,
Thank you so much. Would you have any idea why devices are being shown with different MAC addresses in the "Connected Decives" screen, or how I can identify unknown devices connected (wired & wireless)?
Thank you!!
