Wurlinx's avatar
Wurlinx
Tutor
Jun 21, 2022
n300 wnr2000v5 wifi router firmware latest version
N300 WNR2000v5
1.0.0.78
Spectrum
  • michaelkenward's avatar
    michaelkenward
    Wurlinx wrote:
    N300 WNR2000v5
    1.0.0.78
    Spectrum
    You have a question or a problem you want to fix?
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    • Wurlinx's avatar
      Wurlinx
      Tutor
      Thanks for the response. No, just wanting to make sure I'm up to date.
      • plemans's avatar
        Glad you're not having issues and was just checking firmware.
        You might mark it solved so others aren't trying to fix an issue thats not an issue.
        Thanks!
        Let us know if you do have issues.
    • Wurlinx's avatar
      Wurlinx
      Tutor
      Actually, I do have an issue; but because my firmware question was answered I moved on. However, the additional problem I had was and still is that I cant log into my Admin account/ Genie or whatever that window is called. Before now, I could log into that account( Admin) by using routerlogin.net; but lately even though I use that URL, it only allows me to login with my email address/username. It does not give me the Admin login window at all. So I'm unable to access my router info or make any Advance changes I want to.
      Any recommendations would be appreciated.
      Thanks
      • plemans's avatar
        Try using its ip address and not the routerlogin option
