Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is my Stora 2110 death
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-24
05:04 AM
2011-04-24
05:04 AM
Hello everyone.
I can not get contact with it.:(
Issue:
Power LED during the boot.
1 The Power LED flashes. (as normal)
2 Now it goes out for approx. 2 seconds.
3 Then it flashes 4 times and turns off again.
4 again no light for 2 seconds.
5 Then it flashes 4 times and turns off again.
6 And so on.
I've tried pressing the Reset button.
The change nothing!
It does not matter whether there are one or two or no hard drives install
Nor whether it is connected to the LAN.
Is it dead??
Issue:
6 And so on.
The change nothing!
Is it dead??
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-04-24
03:14 PM
2011-04-24
03:14 PM
Re: Is my Stora 2110 death
Hi,
you may try to do a firmware recovery on your STORA. 🙂 before you do this, take note of your Stora Name, and your account Username and password.
Follow these steps:
• To put the device into recovery mode, power on the device, wait 15 seconds, then hold the reset button while bootup continues.
• The bootup process will take approximately 30 seconds and the blue LED will be blinking during that period.
• As soon as the recovery mechanism kicks in, the blue light turns off and HDDLED1 will turn orange. The reset button can be released at this point.
• Then the device will request a DHCP lease and try to get an IP
> If an IP is obtained, HDDLED2 will also turn orange for 1 second.
> If no IP is assigned the following pattern will be shown on the leds and the recovery mechanism will stop.
Power LED Off -> HDDLED1 and HDDLED2 will blink 3 times together -> All LEDs off
• Once network is up, the download and burn process will begin. During the download procedure the LED behaviour is:
Power LED Off -> HDDLED1 and HDDLED2 will turn on and off in turns
• The download and burn will take around 4-5 mins with a fast connection speed.
• Once the download and burn is done:
o If the burn is successful, all LEDs will turn on for 5 seconds and then the device will reboot normally
o If the burn fails the LED behaviour will stay as follows and the recovery mechanism will stop
Power LED On -> HDDLED1 and HDDLED2 will blink together
Then you can re-configure your device using the Setup CD, use the same product key, Stora name and create the same Stora accounts to recover your data.
Follow these steps:
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-09
04:23 AM
2011-10-09
04:23 AM
I have the same problem.
Pressing Reset has no any effect. And device can't be turned off with Power button - I have to unplug the power cord :(
Please help!!!
Message 3 of 3
Announcements
