Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lost Data Recovery Attemp
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-23
08:00 AM
2010-01-23
08:00 AM
I'm trying to use some recovery software (Stellar Phoenix Lunus Data Recovery) to restore some lost data (over 300GB) and the software does not appear to recognize the platform as Linux as some articles claim it's Linux. It also does not recognize it as FAT, NTFS either. However It does see the S.M.A.R.T configuration and two partitions. The main partition as 938GB and Windows Disk Manager see's the 2nd partition as a Boot Drive.
Does anyone know what the true platform is? Stellar Phoenix says the software is for recovering Linux Ext4,Ext3, and Ext2 platforms.
Link: http://www.stellarinfo.com/recovery-software.htm
Message 1 of 11
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-23
08:19 AM
2010-01-23
08:19 AM
Re: Lost Data Recovery Attemp
If I must mention, there is nothing wrong with the drive. If I place it back into the Stora Box, it surfaces Okay and shows the default folders created by Stora. Since it was reformatted, I have not saved anything on to the harddrive). There is still 300gb of data laid out on the drive somewhere and the software should detect it if it is truly Linus format.
Message 2 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-23
11:39 AM
2010-01-23
11:39 AM
Update:
I was told by a Stora developer and other members here on the forum that the harddrive platform was Linux based. I have tried Linux software to recover some lost data and they would not work. I downloaded different recovery applications and FINALLY I AM AT THIS WRITING RESTORING ALL MY LOST FILES. Today is the happiest day of my life since I lost this data early December or late November.
It turns out the actual file format is NTFS of some unknown type. If you need to recover data, use "Stellar Phoenix NTFS Data Recovery.
For what it's worth, besure to always TURN OFF your Stora when exchanging the drive. Netgear advertises on packages, reviews that it is Hot Swapable and that you need not turn it off. Also, make sure your Netgear Box tilt's just slightly towards the back because the drive can slip partially out of it's slot causing Stora to think it's a 2nd mirror drive and performs a automatic format. I'm not really sure what caused Stora to reformat my hardrive without my consent, but I have a theory it was caused by the latter. It has happened to me twice. I have not had the problem since the unit is tilting back a bit. A tech told me that it should have some paddings and it does, but there is still a little gap enough for the drive to slip out a bit.. You could add padding as well.
I'm really sorry that I may sound negative - it can get pretty upsetting when you lose over 300gb of Photoshop documents, RAW Image and jpegs. Expecially when there are Wedding pictures that the clients never got to see.
Message 3 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-24
12:53 AM
2010-01-24
12:53 AM
did you ever get the wedding pictures back?
Message 4 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-26
07:51 AM
2010-01-26
07:51 AM
The actual file system for the /home partition is XFS.
Cheers,
Roby!
Cheers,
Roby!
Message 5 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-31
08:12 AM
2010-01-31
08:12 AM
happend to me too, how did you recover your data?
Message 6 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-01
07:30 AM
2010-10-01
07:30 AM
Hi! too bad it happened. It's always cool and safe to have a data recovery tool. Most especially if you have plenty of file to keep and protect. I am using one and so far I am not having problems with it.
Data Recovery
Data Recovery
Message 7 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-03
12:54 PM
2010-10-03
12:54 PM
Use UFS Exporer http://www.ufsexplorer.com/
Message 8 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-06
03:17 AM
2010-10-06
03:17 AM
Hi !
You can use a third party data recovery to recover your lost data easily.One i have used last week is Kernel for data recovery software that recovers lost data due to damaged,deleted,corrupted,formatted,partition or virus attacked.It recovers all deleted data over a single mouse click.You can find it from http://www.harddiskdatarecovery.in
Thanks
Thanks
Message 9 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-01-11
04:08 AM
2011-01-11
04:08 AM
Since you have made sure that the storage media you are using has an NTFS partition, it makes your data recovery process all the more easier. This is because there are innumerable number of data recovery software available online to recover files that have been deleted or lost.
Message 10 of 11
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-19
10:47 PM
2011-10-19
10:47 PM
i read from several reviews that this data recovery software can recover data in Linux.
u can download the trial version to see whether it can work with u.
Message 11 of 11
Announcements
