Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Setting up FTP using FileZilla
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-13
03:26 AM
2012-03-13
03:26 AM
Hi all,
Need a little help. I have a premium subscription and have managed to setup a standard FTP connection, but when I follow the instructions to create a secure connection I get the following messages:
Status: Initializing TLS...
Error: GnuTLS error -12: A TLS fatal alert has been received.
Error: Could not connect to server
Status: Waiting to retry...
Status: Delaying connection for 1 second due to previously failed connection attempt...
Status: Resolving address of Sandhurst51.mystora.com
Status: Connecting to 94.168.56.11:21...
Status: Connection established, waiting for welcome message...
Response: 220 (vsFTPd 2.0.7)
Command: AUTH TLS
Response: 234 Proceed with negotiation.
Has anyone had this issue?
Command: AUTH TLS
Message 1 of 6
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-13
05:45 AM
2012-03-13
05:45 AM
Re: Setting up FTP using FileZilla
PaulFargo wrote: Hi all,
Command: AUTH TLS
There's an issue with FileZilla v. 3.5.3. They changed a handshake protocol cipher strength requirement or something of that nature. Try an older version.
Cheers,
Roby!
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-13
06:39 AM
2012-03-13
06:39 AM
Thanks Robyb, I have rolled it back. I did find a answer on the Filezilla site but it required me to add lines to the vsftpd's log which I was unsure about.
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-13
09:29 AM
2012-03-13
09:29 AM
robyb wrote: There's an issue with FileZilla v. 3.5.3.
Cheers,
Roby!
With 3.5.2 FTPES works.
The cipher the stora uses is insecure.
It should be changed to a stronger one, or newer versions of filezilla will not work with the stora and FTPES.
Is this possible, roby ?
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-20
03:13 AM
2012-03-20
03:13 AM
FileZilla v. 3.5.3. is working for me and always has. Im using the default settings. :confused:
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-20
06:33 AM
2012-03-20
06:33 AM
lotust251 wrote: FileZilla v. 3.5.3. is working for me and always has. Im using the default settings. :confused:
Default settings is not the same as FTP over TLS.
Cheers,
Roby!
Message 6 of 6
Announcements
