× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Transmission remote gui settings
t0ph0id
I want to run the transmission remote gui program on my Win7 laptop but not sure what settings to put in.
I had this running before but had to reinstall windows.
What in the fields below so that I can download direct to my Netgear Stora
Thanks
Message 1 of 10
robyb
Re: Transmission remote gui settings
your remote host is storaname.mystora.com . username/password is the ones you assigned to the torrent app in Preferences -> Torrent.
Cheers,
Roby!
Message 2 of 10
ossienet
I've never got this to work either. I enter my stora name as above but I always get "Connection refused" 😞
Message 3 of 10
ossienet
I should add that it works locally OK if I use my local IP address for Stora.
Message 4 of 10
robyb
Did you forward port 9091 on your router?
Cheers,
Roby!
Message 5 of 10
t0ph0id
Great thanks for this.
Message 6 of 10
ossienet
Cheers,
Roby!
Thanks Roby! Port 9091 was showing up on router as enabled, but I removed the port forward entry, replaced it and rebooted the router and it seems to have done the trick!
PS: How come this isn't done via UPNP as per all other port forwarding on the Stora?
Message 7 of 10
robyb
Because Torrent is usually something more advanced users use, and like you, they know how to port forward. So instead of opening a known port for everyone and then getting the odd "omg my security is at risk!!!11oneone" message... we leave it up to you 🙂
Cheers,
Roby!
Message 8 of 10
ossienet
Cheers,
Roby!
Like they do with Ports 50000, 50001 ... which are known ports for Trojan attacks? 🙂
Message 9 of 10
robyb
You prove my point! Those ports are used for secure ftp 🙂
Message 10 of 10
Discussion stats
  • 9 replies
  • 9069 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
