× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
recovering STORA name ?
celt147
Re: recovering STORA name ?
Hi @DexterJB, I have the same issue as above. I have the serial number and product key etc.. However, I do not know the original stora name used.
Could you please help?
Message 76 of 100
Pcyber
Yes you Can find it under nas
Message 77 of 100
Xarmanis
Hi @DexterJB, I also have the exact same issue! I have the serial number and product key and mac address but I can not recall the original stora name used.
Message 78 of 100
fre-die
Hi,
I have the same problem. After may years of service it decided that it needed to register again. I have the product key but not the STORA name. Please advise how to proceed.
/Fredrik
Message 79 of 100
cagi
Hi,
I have just reflashed my netgear stora, and now I can no t regoster it because I don't remember the initial stora name.. Can anyone give me support?
Regards
Message 80 of 100
tornik
Hi Guys
I'm having a similar issue but this solution does not work for me --- PLEASE HELP
I followed the factory reset procedure step-by-step as specified in the Stora manual. Everything worked perfectly.
Now, when i type in the IP address to the NAS as specified, it does not take me to a login screen, but rather to the "Registration" screen : http:///admin/wizards/setup/wrapper. This screen only gives one option : type NAS key + nas name and submit to mystora.com. I have the key but not the name. Does not matter what i type, it simply fails and does not allow me to continue.
key: NGVU-AHKF-ADKZ-FMTW
Message 81 of 100
tornik
i forgot name of stora
Message 82 of 100
npetersen
Hi  I have the same problem   can you please assis
Message 83 of 100
PCF1XR
Hi @DexterJB can you help with recovering my stora name?
I still have the user and password but need to reset the device.  Stuck at trying to remember the name during the reset process.
Model: MS2120|Media Server|EOL
Message 84 of 100
RomanChernykh
Hi, same problem.
I did a hard reset on my NetGear Stora MS2000. But forget the old name Stora. And now I can not re-register. Help solve the problem, please.
Model: MS2000|Media Server|EOL
Message 85 of 100
Pcyber
You can find it under box
Message 86 of 100
RomanChernykh
@DexterJB Can you help me?
Message 87 of 100
Retired_Member
Not applicable
Hi, I have an NetGear STORA that's been unused for a while, it contains pretty important backup stuff.
Today I needed to access the files back into a new computer, and I've been surprised on how difficult it is to access the files.
First I thought that it only needed a factory reset, which I did, and then I'm surprised it asks for a long forgotten device name which was used to register it originally, and there's no way to circunvent it, I'm getting the dreaded "unable to register" text that seems everybody is getting here. And, as the text says, "please, get in contact with customer service" which is what I am doing... and just found plenty of people with the same problem.
I'm new here, it seems everybody is asking to @DexterJB for an answer.... of course, I have the serial, etc, and I even have the username/pass ... but not the device name.
This is ridiculous, the device seems to be running, the HDDs seem to be fine, it's just an ill designed software driver that's giving all these headaches!, so please, @DexterJB help us recover the files!
Message 88 of 100
Littlefly
Rif.: recovering STORA name ?
HI
@DexterJB
I've recovered my stora but I cannot remember it's name -
could you please help me?
Thank you in advance!
Message 89 of 100
PVoltologe
Tutor
The serial *27829B7102EDF* seem to be registered in the pass but the stora name is unknown meanwhile.
What you need to reset the old name so I can use the setup-utiliy for install again.
Thanks in advance.
Message 90 of 100
Hkn
Hi, I have the same issue. I cant seems to remeber the Stora name. I've given up. I found my stora not powering up for a long time. Now it's powered up, but stucked at setup asking for product key (not a problem as it's sticked on the Stora) and stora name (my challange). I have a lot of photos on the Stora that will be to sad to loose.
I will appreciate any tip.
Message 91 of 100
PVoltologe
Tutor
I use the direct message channel to @DexterJB and received the following request:
Please provide any available information about the Stora.
Serial Number:
Current Product Key:
Stora Name:
Username:
MAC:
Dexter
Community Team
After providing what was left in memory or stickers I got the puzzle sorted out by DexterJB provided feedback information and meanwhile I have access again. Probably until April 2020 (there was a message this week that netgear will stop service).
Message 92 of 100
Chrispybacon100
Hi,
I am having the same trouble resetting my stora. I cant remember the user name and thought I could reset but apparently I have to have the same name I put in with the product key? I am just about to bin the unit but thought I would give it one more shot!
Any ideas? Thanks
Chris
Model: MS2110|Media Server|EOL
Message 93 of 100
Dmitriy19
Hello! Please reset activation of the my NAS Netgear Stora.
Password and original stora name of the device was lost.
Produkt key: NGTH-QGFK-BGGD-FTRU
Serial Number: 2783037201055
Thanks!
Message 94 of 100
Andrey_eav
Produkt key: NGJC-PUKD-AWUG-JKTB
Thanks!
Message 95 of 100
vshershun
Hi! I have the same issue with my Stora MS2000
II make Hard Reset it but I cannot remember it's name - could you please post an answer to share solution of the problem?
Vladimir
Message 96 of 100
michalr
Same issue - I don't remember the name of my STORA
Message 97 of 100
MabMarius
Hi @DexterJB i have the same problem. and software on the support site is corrupted, can you help me? Thank you in advance!
Message 98 of 100
cureta85
Hello there,
I bought mi ms2100 long time ago (10 year), i could not register again and I saved. I saw no more EOL service, but can you help me to use it has internal NAS in my home network. PLEASE.
Message 99 of 100
deep88
hey Dexter
can u help me too?
please
i can provide info serial and mac address
Message 100 of 100
Announcements
Orbi 770 Series
