- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
A6210 Installation Blues
- Mark as New
- Bookmark
- Subscribe
- Permalink
I put in the disk and did the installation but it wouldn't detect my adapter. I decided to try and install the driver from the CD but that gets stuck in an infinite loop asking me to insert the adapter and click continue but every time I do it just tells me to do it again. Then I tried to uninstall everything but when I try to uninstall the software it pops up and attempts to re-install itself before failing with an error message. This happens every time I try to un-install making it impossible to get rid of. On top of that whenever I try to use the Netgear set up to just re-install the genie I get error code 1605 which tells me the software isn't even installed.
Everything has been a terrible headache. Even downloading the driver online gives me the same issue as when I installed it from the CD, just an infinite loop that does nothing. I'm using Windows 10 if that info helps.
In summary:
1. My adapter was not being detected in USB 2.0 or 3.0
2. I can not uninstall the genie
3. I can not install the driver from CD or Online
4. I can not re-install the genie since it tells me I have nothing installed to begin with
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A6210 Installation Blues
And the answer is a different version of Genie. The one that worked for me came with my Netgear Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just manually download latest driver and install it. Or don't plug in the adapter until install wizard asks to plug it in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just manually download latest driver and install it. Or don't plug in the adapter until install wizard asks to plug it in. Before trying again delete
all the traces of A6210 stuff from your computer(or PC)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I left everything plugged in, Kept reinstalling : Genie removed and reinstalled itself. However forgot to say I rebooted after install.
This is the particular Item I had previously;
https://www.netgear.com/support/product/WN3000RPv3.aspx?cid=wmt_netgear_organic
Looked a little more into it. Part of it was that it installed another app aswell :
NETGEAR genie Smart Setup
Thats what installed it.
Heres Netgears HIDDEN link....Took FOREVER to find this, hope this helps.
https://www.netgear.com/support/product/Smart%20Wizard%20Utility.aspx?cid=wmt_netgear_organic
