- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
A6210 disconnecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
A6210 disconnecting
This device has problems maintaining a connection to my modem. I have read through the posts about this and havent seen a solution that works. I have filed a ticket but havent gotten a reply for 4 days so will likely ask for a replacement or refund if no one can help fix it within the next week or so from the store. It connects fine though you are forced to troubleshoot every few minutes from loss of connection where windows resets the adapter and it works again.
I've installed the genie then did the stand alone driver. Problems still persisted.
Uncheck the power saving mode in device manager. Problems still persisted.
Set Max USB Speed to 3.0 from Auto. Problems still persisted.
Disable NetgearSwitchUSB in Task Manager. Problems still persisted.
Swapped over to USB 2.0 and set that as Max USB Speed. Problems still persisted.
Driver version is 5.1.35.0 and using windows 10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A6210 disconnecting
I'm experiencing disconnections with this device as well on latest version of Windows 10 ver.2004 and latest driver.
The only thing I found that helps is under Device Manager select this device in Network Adapters--> Power Management and make sure it has a tick in the first option to allow the computer to turn off this device...
Netgear needs to issue this device with a new driver.
Best of luck
M
