× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A7000 USB no longer works with OS Catalina
adairluscher
While traveling I plugged my A7000 (which I use for travel due to weak hotel connections) into my Macbook Air and it appears that it is no longer supported -- no Netgear driver that is online works with Mac OC Catalina v 10.15.2
Is anyone awarre of a solution or has Netgear just decided not to support the product (less than 2 years old) for Mac OS?
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Re: A7000 USB no longer works with OS Catalina
@adairluscher wrote:
Is anyone awarre of a solution .....?
Yes.
Re: compatibility macos catalina - NETGEAR Communities
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1245 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
