× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Activity LED Constant Blinking And Hidden Networks
qw5
This is about the WNA1100 WiFi adapter on a windows 8.1 32bit system -- updated.
Just installed a few days ago and did not notice this continuous LED blinking until last couple days.
Led becomes very dim (but continues blinking) when I click the Refresh button on the “Join a network” page of Netgear genie.
To get the LED bright again, I use the “safe remove / eject” and then reinsert.
Used the latest install software WNA1100_Setup-V2.2.0.1-1_signed.zip downloaded from
https://www.netgear.com/support/product/WNA1100.aspx
Is it normal for the blue led to be blinking all the time -- with no net activity / no net apps running?
Will a hidden network show up in the network list once it has been connected to?
Or could something be connected without showing up in the network list?
Thanks
Model: WNA1100|Wireless Adapter|EOL
Message 1 of 6
JamesGL
Master
Re: Activity LED Constant Blinking And Hidden Networks
Hi qw5,
Blinking LED light means either it is scanning for available networks or the adapter is sending or receiving data.
Message 2 of 6
qw5
Yes, but to be doing this constantly seems strange.
Thanks
Message 3 of 6
JamesGL
Master
Hi qw5,
Is the adapter connected to a hidden network?
Message 4 of 6
qw5
If such a connection would NOT show up in the list of 'connected', then there might be such a connection.
I have only ever connected it to my home Sprint Hotspot and that is the only connection that shows.
Thanks
Message 5 of 6
JamesGL
Master
Hi qw5,
If the adapter has not been connected to a hidden network before then it should be connecting to any hidden network.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3058 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
