Orbi WiFi 7 RBE973
Reply
Ditching my AC600
machg
Follower
Ditching my AC600
So after weeks of trying every fix on the internet I have decided to give up on the Netgear AC6600 adapter. It always triggers Windows blue sreen of death shortly after connecting to the internet. Usualy I get about 1-2 minutes of browsing before windows crashes. Now using the tp-link powerline kit, which operates through the power supply and works like a treat. Anyone wanting an AC600 at a reduced price is more than welcome.
Message 1 of 3
schumaku
Guru
Re: Ditching my AC600
What ever "every fix on the Internet", whatever is shown on the blue screen (usually there is some informative and tech text).
FWIW the current drivers for the Netgear AC6100 are available on the download section. Worth mentioning it contains the same driver kit as available from the chipset maker.
This does allow the computer using it's Ethernet LAN port to establish a convenient Ethernet-like connection to the rest of your network. The powerline kit does just subsitute a network cable resp. a network hub over the power line.
Message 2 of 3
You have replaced one technology (wifi) with something completely different (Powerline). That would have been my suggestion from the start. But that wasn't your question.
Wired is always better than wifi. Powerline won't match a direct Ethernet l,ink from PC to router, bit it is easier to set up (just plug in), more reliable and usually faster than wifi.
tp-link is one Powerline technology I haven't tried. I am mostly on Netgear, but all brands seem to use the same technology.
When it comes to managing a Powerline network, Netgear is mostly useless. (The Netgear desktop genie has some useful features.) So the control software I use is from ZyXel. The devolo option also has its advantages.
Message 3 of 3
Discussion stats
  • 2 replies
  • 861 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
