× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Lost installation CD
Neil_Con
I purchased the above router many years ago, and just recently decided to try using it again. The only problem is i cannot find my resource cd, and cant set up the router. Is there a link to the relevant router software? Thanks
Message 1 of 5
TheEther
Guru
Re: Lost installation CD
Routers don't really need installation CDs. You can configure them with a web browser. Go to support.netgear.com and type in the model number. You can download the online manual which will contain instructions on setting up your router.
Message 2 of 5
Neil_Con
Downloaded the manual, but it says i need to set up using the set-up wizard (which if i recall, was on the resource cd)
Message 3 of 5
You haven't said which device you are using – I see no "above router" – but most manuals will tell you how to do a manual setup.
The quick start/installation guides are less helpful on that front.
For more advice, tell us the model number on your device.
Message 4 of 5
@Neil_Con wrote:
I purchased the above router many years ago...
You have posted this message in a forum section dedicated to WiFi Adapters.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2579 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
