- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No access to router A6210
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all. I'm in a hotel and cannot physically access the router. Is there a way for me to connect the A6210? I'm talking about the WPS feature of the adapter.
The Netgear software is loaded on my laptop.
Thanks in advance for any help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No access to router A6210
You should be able to connect to the wireless using the password they provide you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello and thanks. 🙂
Yes, the hotel has provided the password for its network. It appears that I have misunderstood that I require _both_ the network password _and_ a WPS connection. After reading your response I now understand that the WPS is not needed.
Unfortunately, when I use this A6210, the internet speed remains unchanged. No improvement. I am using a USB 3.0 port.
QUESTION
Is there a way that I can fine-tune the Netgear driver or my Windows 10 settings such that the A6210 delivers more speed?
PS: I can see that the A6210 is operational when I check device properties within Windows 10. Additionally the laptop detects or sees many more wireless networks when the A6210 is plugged in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
most hotels limit the speed per device so they can supply the whole hotel.
You can try checking with them but their front desk is unlikely to know
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your assessment of the hotel environment is correct I believe.
All is not lost, as the USB adapter _does_ pull in many more available networks. Although I won't be using those additional networks, their presence, when using the USB adapter, indicates high gain. And, consequently, the possibility of better streaming and fewer dropped connections on the network that I _do_ use. Even if speed to my device is capped by the network.
Not ideal. But better than nothing.
